Official 1/4 MILE ET RANKING: 4V ALL MOTOR
psfracer
billy badass
Valencia, CA
4v ALL MOTOR RANKING​
image1.jpeg~original
KDanner.jpg~original
#1 KDanner
#2 MATT D
wbt.jpg~original
#3 WBT
11Sec3V.jpg~original
#4 11SEC3V
#15 GEORGEINNEPA
Fiveoh.jpg~original
#28 FIVE-OH
LIST UPDATED BY FIVE-OH 2/27/2015
psfracer
billy badass
Valencia, CA
To add your timeslip to the 4V All Motor list, post here.
NO OTHER CHATTER, just timeslips please. To discuss your new best, you can create your own thread in the drag racing forum.
RULES:
For your time to be added to the Official ET Ranking List for your category, you will need to post the following:
1) copy of timeslip--if you don't have it, unless you have video, forget it. If you only have video, please provide the 60', 1/8-mi and 1000' incrementals
2) The following vehicle information:
- Cubic inch displacement (CID) of engine
- Type of transmission (by model number)
- Size and Manufacturer of power adder, or N/A
- Pounds of Boost, of N2O shot (or both if applicable)
- Rear Gear ratio
- Make and type of tire
3) your time also has to be backed up by another time within 2%. This is to eliminate "candy wrapper" passes (time clock errors).
warmmilk
- 302-4V
- MT82
- 3.73
- Stock Pirelli P Zero
- Relevant Mods:
Kooks catback, Barton 2 post, CJPonyparts Clutchline, ST Coilovers, BMR LCA, Panhard Rod, and Relo Brackets
FIVE-OH
FYI guys, I am in the middle of updating the list. It will be done tomorrow at some point...
So, if you want to make sure you get on the list post your slip in this thread with all the info asked and you will be added.
The old thread will not count, so if you do not post in this thread, you new times will not be added as we can not all go through that old huge thread.
Members whose cars are not all motor anymore, sold, or have not logged on in the past 6 months or so will be removed from the list as per psfracer.
Thanks!
kdanner
Austin
302-4V
6R80
stock heads
stock cams
N/A
3.31
Hoosier slick
Sledder
SE Mich
12.205 @ 114.71 backed up with a 12.350 @ 113.65
Cubic inch displacement (CID) of engine: 302 4V
Type of transmission (by model number): 6R80
Size and Manufacturer of power adder: N/A
Rear Gear ratio: 3.73
Make, type, and size of tire: M&H DR 275/45/18
2012 GT, Auto, M&H DR 275/45/18, Alternative Auto Performance Tune, BBK Longtubes, Catted X Pipe
__________________
Five Oh Brian
Mustang Guru
2014 GT Glass Roof Coupe
  • 302 CI / 5.0L DOHC Coyote V8.
  • 6R80 6-speed Automatic, 5000 rpm stall converter.
  • Naturally Aspirated.
  • 4.10 rear end gears.
  • M&H Racemaster drag radials (28" tall).
  • 100% stock engine & suspension.
  • O/R H-pipe & GT500 mufflers, stock manifolds.
  • Heavy, loaded car: 3850 lb race weight with me in the car.
Most recent timeslips (8.22.14 / Bremerton Raceway). Car #2061. Best 1/4 mile 11.804 @ 117.70...
FIVE-OH
Okay guys, this is the stopping point for this time. Any slips before this will be on this list, any after this post will be on the next edit. I will try to edit them every few months or so. I am sending psfracer the updated list now...
So keep posting your slips. There is no limit on this list, so even if your car is stock, it will still get added to the list.
Thanks.
wbt
I believe my times should be updated:
302-4V
6R80
stock heads
stock cams
N/A
3.31
Hoosier D/R
stang8psi
Slower,Lower Delaware
11 gt premium
302 ci 4v
N/A
mt82
3.73 gear
18" wheels and tires front and back
Nt555r 305/40/18
Stock heads and cams
11.5:1 bottom
Boss Mani
long tubes
rev auto tuned
TungstenGT06
Morrisville Pa
2014 GTCS
mt82
3.55 gears
Stock 19" tires
Boaisy
Dark Knight
Memphis, TN
2012 GT Brembo Premium
302 4V
MT-82
3.73 Gears
Truetrac Differential
Tires Hankook S1 Noble2 255/40-19
Steeda CAI 101mm
Lethal O/R H-Pipe
Borla Touring axle back
Dynospeed 93 Tune
Carbon Fiber DSS Driveshaft
Whiteline Front and Rear Sways
Whiteline Watts Link and UCA
BMR LCA and Relocation Brackets
FIVE-OH
I will try to do an update to the list tomorrow. Only cars with two slips posted, and ones that followed psfracers rules can be added.
JLear
2014 GT
Central Kentucky
2014 Gt Auto Full exhasust, Mike Rousch tune, lca's, and 275-50 MT ET Street radials. 302, 6r80, stock trans, and 3.15 gears.
Best pass was 12.06 @ 115.91
