2007 Mustang Fuel Pump Harness 5R3Z9D353AA
despinos
Albuquerque, NM
Needing the connector from this harness that goes to the fuel pump. It was brittle and cracked when I went to swap pumps.
EBABlacknChrome
Michigan
I had a hard time finding fuel pump connectors, even identifying them. I think I have a chart that shows that actual connector.
despinos
Albuquerque, NM
That would be great if you did. The car has sat for a few years and I'm getting it running again, but most of the connectors I'm removing are brittle. Local ford hasn't been much help, and alot of parts have been discontinued through Ford.
EBABlacknChrome
Michigan
Sorry for just getting back to you. I actually found parts from Fordparts.com. that's where I was able to identify my parts anyways. Hopefully you have located what you need. You should be able to de-pin it without out cutting. 1000013330.jpg1000013329.jpg
