05 Shifter Overdrive Button Removal
Joe combs
Northern Kentucky
yes... remove the console top...there are 4 snap lock areas on the shifter top, you can push on them to release the top. once you have the top loose, locate the white wire on the passenger side of the shifter. there is a small tab holding the connectors together. once you have that loose there is a small torx on the front of the shifter handle, remove the torx, the gently tap the shifter handle upward to remove it.
07 Boss
Sin City
Hey, has anyone successfully removed the overdrive button from an 05 to 09 Mustang GT shifter without breaking it? Need to know how. Thanks.
Can I just ask why you want to remove the button from the handle? Curious.
AboStangster
Ottawa, Ontario, Canada
20201015_120955.jpg Not quite.
I'm working with a variation of the White Madness ball shifter. If it works, it will look more like a standard shifter, but work as the normal shifter but without overdrive. I still want to use my overdrive button though, so will have to do something separately.
AboStangster
Hey,
Thanks for asking.
I connected it to a separate
12mm DC Power Button 5V LED, Waterproof Latching Push Button Switch On/Off 23V (Red 2V).
I dropped it into the console to the right of the shifter.
I set it for the LED to be on when overdrive is off.
I hope this helps.
  1. 12mm DC Power Button 5V LED, Keenso Waterproof Metal Momentary Type Selfresetting NickelPlated Push Button Switch OnOff Latch Button Switch 23V (Red 2V)
