recordbreaker5
Blown 3V
Original owner took the car to a authorized Saleen dealer and had the cosmetics and suspension package added to the car. Odometer reading is right at 48k with roughly 5k miles on the new motor. Car was completely torn apart and rebuilt in 2009 with 41k miles. Spun a bearing on an aluminator shortblock and had it rebuilt with better parts while I was overseas for 2 yrs by Mark @ Panhandle Performance. The heads were torn down, ultra sonic cleaning and reassembled. I have the build sheet for the motor, specs, receipts, etc in a folder for the entire car. The best parts were used on this car, I didn't take any shortcuts with it. Any additional questions, I'll be happy to answer. Thanks
Engine-
-284ci 9:1cr Panhandle Performance built
-Manley 14cc dish pistons w/coated skirts/1.2mm offset tool steel pins
-Manley H-beam SVT rods
-Total seal SS rings (AP top, NAP second, H-TNS)
-Kellog Forged "Cobra Crank"
-ATI super damper balancer
-Moroso 7 qrt aluminum deep sump oil pan
-FRPP CNC ported 53cc 3V heads
-COMP custom grind blower cams (have cam cards in folder)
-COMP 20* phase limiters
-COMP beehive springs w/ steel retainers
-ARP head studs
-Brisk Silver Racing plugs
Induction-
-FRPP intake manifold
-FRPP twin 62mm throttle body
-SCT BA-5000 MAF
-Procharger 3-core intercooler w/ 3 inch piping
-Procharger “Big Red” race valve
Power Adder-
-F1-A Procharger 12-rib w/ 4.75in and 3.7in pulleys
Fuel-
-FORE triple hat return
-3 Walbro GSS342 fuel pumps (1 not installed)
-FORE F2 regulator
-FORE Y-block 3 to 1
-FORE Y-block 2 to 1
-FORE fuel rails
-FRPP 60 lb/hr injectors
-(-6/-8) stainless steel braided fuel line
-AN high flow fittings
Exhaust-
-Kooks Long tube 1 5/8 to 2 ½ collector w/ Stage 8 lockers
-Kooks High Flow X pipe w/ gutted cats
Drivetrain-
-TR6060 6 speed transmission
-GT500KR short throw w/ FRPP shift knob
-Dynotech aluminum driveshaft
-SPEC 3 8 bolt aluminum flywheel
-SPEC 3+ clutch and pressure plate
-33 spline Auburn pro differential
-Moser 33 spline axle w/ 9 in bearings
-3.55 gears
-FRPP differential cover
-Welded tubes
Suspension-
-BMR tubular K member
-BMR lower controls arms
-BMR adj. upper control arms
-BMR adj. panhard bar
-Saleen N2 racecraft struts/shocks/springs/swaybar
Interior-
-Autometer/procharger boost gauge
-Autometer/procharger fuel pressure gauge
-Autometer oil pressure gauge
-Innovate LC-1 wideband (left bank)
-Innovate MTX-L wideband (right bank)
-Speed of Sound triple pillar pod w/ raptor shift light -SCT Livewire
-Black leather interior
-Tinted windows
Stereo-
-Pioneer AVIC-D3 head unit
-Kicker 1500 watt amp
-3 Kicker Comp 10” in custom fiberglass box
-2 Kicker Comp 8” door panel
Wheels-
-HD MSR 20x10(r) 20x8.5(f) (powdercoating blk)
-Toyo Proxes 275/35R20(r) Toyo Proxes 255/35R20(f)
***The car made 675/550 @14 psi @17*. I will post more pics when I get home from work this evening. Car is in my signature.***
$23k http://d3racing.com/Mike2005.html
Engine-
-ARP head studs
Induction-
-SCT BA-5000 MAF
Power Adder-
Fuel-
-FORE F2 regulator
-FORE fuel rails
Exhaust-
Drivetrain-
-3.55 gears
-Welded tubes
Suspension-
Interior-
-Tinted windows
Stereo-
Wheels-
