2012 Build Thread
Double0fox
Tacoma, WA
So first off, to get to where I am currently at in the build stage is going to take some posting. The car has came ALONG way since I bought it. I will post in bold at the top of the thread when I am to where I currently am, but it might take me a couple days. Alright where do I start. I will try to put all of it together from the last year. I love having car projects. Sometimes I think to much. If I was super rich, I would still be broke from all the cars that I would have. Quick back story though. I used to have a 2000 GT that went through soooooo many changes. Nitrous car, then Supercharged(TorkTech), and was eventually going to get a big single turbo, and bought a Teksid block to build off of. I built/changed everything except the transmission (not even joking, and not sure how that T-45 survived for as long as it did). I was in tear down mode again when I moved from Oregon to Washington. The Mustang sat for the first year I was up here, and then I bought another car that I had wanted for a very long time (Not a Mustang so won't get into that), and unfortunately it went on the back burner for a while. A few years back I was offered a job in AZ(I currently live in Tacoma WA), and wasn't going to be able to take it with me, so I sold the project. What pissed me off is I didn't end up taking the job after checking out the facility in person. This left a small hole in my heart for a while. Fast forward to last year and at this point I was dailying a Dodge Ram, and it wasn't exactly a "fun" daily. So with a space in the garage I started looking for a 2011-2014 GT as a daily driver. I was looking for a Grabber Blue, but I could not find a manual, with low miles that fit the bill. Then I ran across this online. A "race red" 2012 GT Premium M6 with 4500 miles on it, and 100% stock. When I first saw the add for it, it said it had only 4500 miles. I thought the dealer had made a typo, and it was 45,000. So against my normal behavior I called a dealership to talk to a salesman. He said ya only 4500 miles. I asked for a pic of the odometer, since I didn't trust him....or any car salesman for that matter. Sure enough 4500 miles on her. The next morning I took the day off work, and brought it home.
Even while I was waiting to take the car home at the dealership, I was ordering parts.
SVE Drifts 19x9.5 (came with 18x8's with 235's)
285 19 Nitto 555 G2's (All 4 corners)
Steeda Sport Springs
Koni STR Shock & Struts
Cervinis Boss/California front lip/splitter
BMR Control Arms
BMR Panhard Bar
RTR competition Axle Backs
Double0fox
Tacoma, WA
One thing I did do though was weight the car before I started modding.
This was completely stock with everything (floor mats/spare what not) in the car still with fuel exactly half way between 1/4, and 1/2 tank with me in the car. I weighed my self when I got home and was at 180 lbs. So about 3600 lbs even. Damn tank. One thing I haven't done after all the changes I am currently at is have it weighed again. I have removed alot of weight, but at the same time added some to it, so it should be interesting when I do.
Couple more Pre-modding pics
Tiny rear tires!
Double0fox
Tacoma, WA
Over the next few days I installed:
Steeda sport springs (Stock Spring rates 131F/167R lbs/in) (Steeda Sport spring rates 200lb front, 175lb rear)
Koni STR Shocks & Struts
GT500 Strut mounts
BMR Adjustable Panhard Bar
BMR Panhard Support Bar
BMR Lower Rear Control Arms
When I ordered these springs/shocks/struts I had the plan for this to be just a decent riding, but better than stock daily driver not track orientated, but ya we will get there.
Spring diffrences:
Out come these bastards:
Before & After:
Getting to the rear Shocks from the trunk:
Factory non adjustable panhard bar, and brace:
Both braces:
Both panhard bars:
Control arms:
Double0fox
Tacoma, WA
One of the next things I had to change was the shifter. I really REALLY do not like the stock shift linkage in this car. There are probably better things in life to bitch about, but it needed to come out. So in went MGW's X-Spec Race Shifter. The stock shifter linkage is remote mounted versus the MGW unit having actual transmission mounting to the unit. Once you have the MGW set it is soooooo much better, and what a piece it is. I am in the machining industry, and I say, it is well made! Plus it is so much more satisfying to shift this car now. Also at this time I added a Boss 302 Alcantera wrapped steering wheel. I had the leather wrapped wheel, but prefer the Boss wheel.
Out with the old:
Double0fox
Tacoma, WA
So I was still in the thought of this car is going to be a daily that I might take to the track once in a while. One thing that I am pretty adamant about is weight saving where I can. Cars these days are getting ridiculously heavy. So I ordered a BMR Tubular K-Member. It drops 22 lbs, while also giving a lot more room to work around the engine. And my thought was that while I had the K-Member out this would be a ample opportunity to put long tubes in! So I ordered some BBK Long tube headers, and a Off road (no cats) X-pipe to go in. So after getting everything Installed I started it up, and holy hell it was LOUD. Like I wouldn't even dare go half throttle loud. I enjoy a louder car, but with the RTR Axlebacks it was super loud. I even ordered a catted X-pipe in hopes it would reign in the loudness, but no dice. (barely made a difference actually) At the time I was leaving my house for work at 3:30am, and I was sure I was going to be stabbed by my neighbors. I drove the car to work for 2 days, and threw the stock axle backs on just for life preservation. Although the stock axlebacks now made it too quiet, plus I had a rattle I was hearing coming somewhere from the exhaust (that I would later realize was caused by the pan to K-member clearance). So off came the long tubes for the time being. Yay.
Factory K-member, with the electric steering rack.
Factory header vs the BBK Long tube.
Stock headers:
BBK's on:
Double0fox
Tacoma, WA
So after some time I added on the Cervini's Front lip which not only looked better would also benifit me later on in the build with it's brake duct holes.
Started by taking the front bumper off.
Stock front lip vs the Cervinis;
Also around this time I added a BMR Strut brace:
After the headaches of the K-member clearance issues that I would find later, and removing the long tube headers due to hearing vibrations (thought the vibration was not coming from the long tubes). I decided to leave it as it was (for the time), Kept all the exhaust, but just put it in boxes for the time being. At that point she was looking pretty good, and was fun a daily:
tjm73
of Omicron Persei 8
Rush, NY
Nice car. Tasteful mods so far.
Double0fox
Tacoma, WA
At this point I had been driving it into the winter time, and when there are no longer any outdoor hobbies over the winter time I hopped on the Ol' Internet, and was browsing a few Mustang forums when a member in WA had a set of Boss 302/GT500 front calipers for a good deal.....soooo bought them, and on they went. I had always planned to up the braking ability on this if I was going to take it to the track. The stockers would probably only put up with 5 decent laps before fading. I never tested this, but given the weight, and power, with tracking at the Ridge (local track) with I would say was 2 heavy brake zones, I just didn't see these being anywhere near adequate. The Boss calipers are complete bolt on, but the disc size goes up from 13" to 14", and pad size is also increased for the Boss. I checked over the seals, and cleaned them up a bit, and on they went.
Stockers:
13" vs 14" disc:
Iceman62
Bullitt 6005
NE
Wow...amazing things going on here - keep it up! Sweet 'Stang!!!
Double0fox
Tacoma, WA
So it was either Jan, or Feb, and I was on my way home from work when I was taking a off ramp and mid corner of the offramp something on the car broke, and made the car lurch over a few feet in the lane. Luckily I did not hit the divider wall, or anything else for that matter. Babied it home to find one of the strut ears had broken at one of the welds. Giving it a closer look, it looks like it wasn't ever fully welded like the other strut was. The car had never been in a accident, or really any hard driving(getting there). I had contacted Koni, and they asked if I wanted to send it in to have it looked at, but knowing that probably nothing would come of it , and how these were their lower line I decided not too. I have had quite a few Koni products over the years be it OEM placments, or aftermarket, and always had good sucess/liked them.
Since I have had a good rapport with Koni up untill this point it didn't make me think twice about ordering some "replacements" in the form of Koni Adjustable Yellows. A much better track suited (defiantly not race coil overs though) strut/shock combo.
Also at this time I installed the BMR Adjustable lower control arm brackets as seen installed here.
OX1
Jackson, NJ
Never heard of that happening before. Crazy!
Me either, but I'd say about 3-5% of the stuff I get from china has at least shipping damage
(or many times obviously damaged before they even put it in the box). Haven't had much
problem from all the vendors getting replacements with no questions usually. I think they
all know a certain amount of parts are going to be bad no matter what. Scary with something
like that if it happened on track though................
tjm73
of Omicron Persei 8
Rush, NY
I'd be more concerned about that happening in daily commute traffic.
I had a ball joint failure once years ago and it was a handful to get it stopped. When I touched the brakes it darted to the right. So I had to brake steer away from the ditch, brake steer away from the ditch, brake steer away from the ditch, until I could get it stopped. It was night time on a back road. Once I got it stopped I got out and was ranting and cursing the car. My buddy that was with me gets out looks it over, calmly turns to me and so dryly says "At least its not tomorrow morning on your commute to work."
Shit going wrong can be just as bad in traffic.
Are you running some monster front swaybar??
Double0fox
Tacoma, WA
This was my thought as well. After some inspection you could tell th e main weld didn't penetrate the body of the strut. I closely looked over the Koni Yellows when they arrived and the welds looked fine.
Double0fox
Tacoma, WA
At this point I think I owed the car for about 8 months. I am currently racing karts, and I used to have a track only 600RR, but I have never had a more track purpose car. So I ditched my plans of having a daily, and decided to make it streetable still (just not street friendly) but more track focused. So knowing that this car was going to see some abuse, and knowing the high RPM shifting problems the stock clutchs tend to have, I decided to get ahead of the game, and change the 10,000 mile clutch(lots of miles right). And I though I would "do it all" while I was in there. So on the parts list were added
Spec Stage 2+ Clutch
Spec Billet Flywheel
All new bolts/hardware
New Ford Throwout bearing
SVE stainless clutch line (why not)
I also added a SVE clutch fluid reservoir separating the brake, and clutch fluid reservoir.
And while I had the car in the air I decided it was time to do the upper control arm, and mount.
Should have dropped the exhaust, and drive shaft when I installed the MGW, so much more room to work. Dropping the trans on you own, on jack stands sucks.
New HD pilot bearing.
Also added a bump steer kit at the same time. I might change this up in the future to a Howe Racing design.
