05stroker
Never enough power guy!
I got mine from PA for 300 something ... LOL... Though it is SFI approved.I got mine from Livernois for $89
8 bolt FP for PI converter.... and I think it was 39 for the ARP bolts
It all depends on the converter you may have to trim the converter plate some if you use your stock converter, i think. Also the flex plate we use we re drill the holes for the mounting studs. Its a ford racing part #....
Both the OEM and TCI T/Cs use an adapter plate that bolts to the front of the T/C housing (that MUST be properly aligned). That adapter plate in turn bolts to the flex plate. The OD of that adapter plate must be machined smaller to fit with most aftermarket flex plates. Keep in mind the TCI T/C is nothing more than a reworked OEM T/C.What do you mean "trim the converter plate"? I'll be using a stock or tci converter.
Also, what ARP bolts do we need for these. (I'll be using a 8-bolt, too.)
Thanks Other than the critical alignment of the converter bolts, what about shimming/spacing issues? Using the ford flexplate listed in this thread.
Jim III- if I'm understanding you correctly here's the deal:
The FRPP M-6375-H46 flex plate will work with the OEM (or TCI) torque converter if you trim the OD of the factory adapter plate and enlarge the 4 stud holes in the flex plate.
The FRPP M-6375-H46 flex plate will also work with the PI T/C with no trimming of the adapter plate as the PI T/C doesn't use an adapter plate.
Questions:
Do you have to enlarge the holes in the flex plate for the PI T/C.
Any issues with using the OEM starter with this flex plate or any other modifications required?
Yes that is all correct and yes even with the PI converter you have to enlarge the holes for the converter studs. No issues with the OEM starter being used. No other modifications required!
The stock ford V10 triton flex plate is 8 bolt and will bolt up to the PI converter with no modifications. This is what I am using. I will post the part number for it later today after I go to the shop. I have posted it before in other threads or maybe PMs.
in the pics, you have holes marked with an 'x' and next to those are studs sticking through; which are the holes needed?
would upgrading to the billet servos potentially help? Considering also an entire rebuild with the hardened input shaft.
I too am getting the FRPP flexplate and plan to use it with a PI converter.
Tmcolegr, in the pics, you have holes marked with an 'x' and next to those are studs sticking through; which are the holes needed? Seems the studs or bolts are at an angle.
(I dont have my plate or converter yet so I can't just go out and try it yet.)
And my tranny is out; would upgrading to the billet servos potentially help? Considering also an entire rebuild with the hardenned input shaft.
It's real easy call jim@jdm order this part and for another 50 bucks they will trim the ring and drill the holes
not trying to
but the ring that must be trimmed is the adapter plate that bolts to the front of the OEM torque converter. So you will either have to ship that to JDM, have a local machine shop reduce the OD, or do it yourself.
