I finally got more than 2 nights in a row at home and made good use of it. Pulled the rear end out to weld up the LCA relocation brackets, install the 3.73's and build a custom breather, then set it back in to mount the watts link and adjustable rear sway bar. Moved on to the transmission to swap in the 6060 and new MGW shifter. While I was still under the car I welded in the BMR subframe connectors. Replaced my shift boot and console cover with some new pieces from Redline goods, installed my UPR billet inner door handles and wired up the traction control auto off relay. Threw in the adjustable front sway bar during the melee. All I have to finish up is the custom oil breather catch can. The car hasn't had a real bath in forever, so I'll get some photos after that happens. Of course, I'm back on the road Wednesday.....
I'll also post up some photos of the custom ramp setup I built. It puts all four wheels 9" in the air.
