Add fog lights: tap in location?
Cardriver333
Sac
I'm adding American muscle's halo fog lights and am looking for a good place to connect the positive side. Can I tap it in to the positive post that powers the fuse box? I'll include a photo of the spot I'm talking about. Thanks!
cavero
NoVA
I haven't done fog lights, but on Saleen's HID headlights, that's where they have you tap for positive power to their relay harness.
Cardriver333
Sac
Thanks, I did put it there and it works great. Now I wanna get their "halo" feature working when I have the parking lights on
DieHarder
Then tap into the parking light wires?
Correct if you're only doing halo's. I built my own (using a kit) and tapped the halo's into the parking lights. Works fine. You could run a separate circuit and add a switch but why bother when everything is easy to get to. Just pick up a basic connector/socket off ebay/local O'reilly's (so you can service it/make it removeable) and tap into the parking lights each side (see pic). I also recommend soldering vs butt connectors but up to you of course.
VGMStudios
Canada
@DieHarder nice! I made my own headlights too. But I tappeed my halos into the DRL circuit and made my own circuit for them to work properly. So when I turn on the headlights the halos turn off. I also believe in soldering vs butt connectors!
