Cali HP Addict
Hey all,
Stuck in Cali here and I have been running a custom tune on a N/A big bore stroker (322ci) forever. Now, I have to put a stock tune in it to pass the smog requirement. Has anyone done this?
By my rudimentary calculations the displacement is approx 15% greater than stock. I also run ported big valve heads and fairly mild Comp 127-301-9 cams.
I would:
- swap my cobra 39# injectors for the stock 24#
- re install the cmcv's under the intake
- re install the stock air cleaner box
- already run the stock fuel pump system
How much can the stock tune add to compensate for the larger, more efficient motor?
I only need it to run decent enough to put 50 easy miles on it and take it in for the test.
Any wisdom from this group is greatly appreciated. Thanks
I would:
