I am on my second tuner and this was my fourth revision and I'm still having horrible issues with cold starts. I had one revision that idles around 14.4 on the wideband but the tip in goes so lean that it cuts out, it will fall on it's face or die. The latest revision idles at 10.1 on the wideband and does the same thing and that's where I left off with the previous tuner. The car runs damn near perfect when the engine is warmed up to operating temperature but I'm not sitting around for 15 minutes before i take the car for a drive. The first tuner told me this was normal for a car like mine but it's not that wild of a setup, keep in mind I'm on a stock long block.
Is there anything other than the tune that could cause the issue? I don't think there is but just want to make sure. I would like to figure this out before ruining another set of HT0's or wash down the cylinder walls from excess fuel.
