Me being the dipshit I emptied out the water in my ice box on a hill and filled it with ice. My iat's jumped up to 198 I figured out that the pump is running, but the water is not flowing. I need to prime it, how would I do this please?
John I did the same thing to your car once. What Don said will work. Just disconnect it where it dumps back into the tank and suck on the hose it will start working. ( and before you ask NO we are not playing a joke on you.)My IC pump quit working at the track 2 weeks ago due to a leaky connection. I drove it home no problem. Then next morning, it just started working again.
As far as priming it, not sure. You could pull the inlet hose off the ice box and suck on it, trying to draw water through the pump.
But the thought of John sucking your hose is OK????eww Ken, the thought of you sucking my hose is a little disturbing
Do you have Meziere IC pump? I thought you were using the same pump I have (you gave me the PN).idk what pump you have but on my meziere i have a plug i can pull out to let the air out of the pump to get it to pump again
My pump keeps quiting on me I am giong to re-route the hose from the back of the blower. Right now it dips down and comes up.
You may want to rule out it's not a an issue of voltage?
Then yep, check your flow and check all the lines for cracks/tears.
your sure the pump is on? (you can hear it)
