HOw much was the labor for the Pistons and Rods?
-John
Just wrote up something similar on another board...
Pulling an engine and rebuilding it is EXPENSIVE. For all who are thinking about it, be prepared to spend about $7K to remove the engine, tear down, clean it, prep it, machine it, put the forged parts in, balance it, hone the cyliders and deck, replace all gaskets, and then reinstall and test is a time consuming and costly process. My understanding is that even buying a swap block is still roughly the same cost.
You cannot just open the bottom end and replace the rods and pistons, anytime you open the bottom end you have to re-machine and rebalance, and you also have to drain and replace all fluids and gaskets and seals. Also, remember, a lot of bolts and fasteners are onetime use, so you have to replace those. All of this is why everyone says build it right the first time.
Kliestang, I've read your post and I'm still not getting the feeling of what you are looking for? Do you want to hit 700HP? For the parts, go with the seller that provides the brand name you want. I've seen many times on these forums that the rods are all made at the same place, so as long as they are H-beams with ARP2000 heads, they will be fine, and since you honestly aren't going to push 1200HP, you really shouldn't get too hung up about them. Almost all of the forged cranks appear to be Kellogg cranks, so they're all good. The real thing to worry about is getting good forged pistons and rings, with the right compression ratio. If you are racking your brain about this, I suggest you go with the most reputable company that specializes in just engines and rotating assemblies...Livernois...or talk to Larry_H on Modfords or this forum.
Call Livernois and ask about their 3V rotating assemblies, I understand they balance their kits down to 1/25 gram. The real key for you seems to be get a solid performing kit, and keep the cost down. A $2000 assembly will probably more than exceed anything you plan to do to it. Now you need to think about the other stuff you'll have to get...fuel system, driveshaft, upgraded tranny and stall converter, gears, input shaft, suspension mods, gauges, dyno tune, ect.
Last thought, make sure you have a good builder put your stuff together. If you haven't done an engine before, get help!
-Darth
