Earl ..... I have been in KY. so just now got back home.Thanks Terry, it is still being put back together. I hope to have it back on the road the first part of Jan. The new shortblock is all done and I delivered it to the shop, so it's just a matter of getting everything rewired and installed.
When the phaser came apart it was just the spring that came loose but, as well as knocking a hole in the valve cover, it got under the chain and made the pass side jump time. All new valves, guides, followers, adjusters and valve job on the pass head were required. Also needed a new set of pistons and I went back to stock compression with the new set. I didn't like the way the engine performed, during normal out of boost street driving, with the low compression pistons I was running.
Like I said shit happens and you just have to go on. I will have it back better then ever next year.
Earl
I know you are looking forward to this New Combination for sure coming in Jan. 2013.
Terry
