mAnYsTyLeS
Is it needed for all automatic Mustangs? I heard that stock mustangs and modded mustangs tend to spill some fluid. Would it be beneficial to get one?
"All" is a fairly broad term. However, I have one on my 05.Is it needed for all automatic Mustangs? I heard that stock mustangs and modded mustangs tend to spill some fluid. Would it be beneficial to get one?
I HIGHLY recommend one for any car using a tune, JDM or otherwise. Higher shift pressures really increase the rate and frequency of the automatic burping little bits of fluid.
I just don't want to see people burning up automatics because it evacuated a little bit here and a little bit here and all of a sudden you're down a couple quarts. Or worse our guys/girls at the track chucking fluid under a set ofhot slicks at 17psi doing a buck twenty...
The only somewhat hard part is getting to the 90 at the top rear of the transmission to attach the hose. On a lift with thin arms it's no problem. On your back on a creeper it seemed impossible.
If you're referring to the fitting on the trans. extension housing, did you know that fitting pulls straight up out of the transmission with little to no effort?The only somewhat hard part is getting to the 90 at the top rear of the transmission to attach the hose. On a lift with thin arms it's no problem. On your back on a creeper it seemed impossible.
We would be happy to install these for any customers who did not want to struggle with installing it themselves.
I better pick one up myself.
My car did this before the Whipple also, just not as much.
Yes mine still blew fluid everywere with the pan and extra fluid.I have a catch can that has been sitting around my casa for almost a year now, and I need to put it on the car. BUT, is it still necessary if I get a PA Deep Sump Pan w/dipstick?
