fiveoh
- Joined
- Jan 18, 2011
- Posts
- 256
- Reaction score
- 0
I was looking at the 2.8 KB kits for the 5.0. Is there a huge difference between the LC and non LC? I'm guessing the non LC get hotter?
I have a roush and on those hot days at the track or even driving around the blower gets pretty damn hot and performance suffers. And mine in cooled. I can't imagine how bad it would be if it was as just left to heat up with nothing helping it cool down. I wouldn't waste the money on non cooled. Imo
The LC doesn't cool the blower case, it only cools the gear case at the front of the blower. Regardless, it's a good thing. If I were to buy a KB, it would have to be the LC.
Or just buy a whipple/tvs and get a better blower...
Positive displacement hierarchy:
< Whipple (cast case twin screw = looser tolerances between case and rotors due to disimilar metals = higher iats than KB) < KB LC blowers (both case and rotors are machined from same alloys)
TVS (not a twin screw) < Whipple (cast case twin screw = looser tolerances between case and rotors due to disimilar metals = higher iats than KB) < KB LC blowers (both case and rotors are machined from same alloys)
KB LC blowers use a different rotor pack than non-LC blowers. Liquid cooling the snout allows rotor / case tolerances that Whipple can only dream about. The rear of these blowers is cooled by the air flow through them. The front (without the cooling option) gets heated up due to the gears spinning at 15,000+ rpm in a cup of oil. To counteract the expansion of the rotors and case, they add more clearance between them, this leads to turbulence and more intake air heat...and less efficiency.
Sure sounds good on paper. Too bad in the real world it doesn't quite work out that way. KB's IAT's are considerably hotter than a comparable Whipple. All day long.
OH - MY - GOD!! You've done it now! Call the local hospitals up in Michigan folks and check to see if Jason has been admitted for a stroke after reading this!
