Livernois Motorsports Big Bore Block Sleeving Demonstration
Dearborn Heights, MI
Below is a video showing Livernois Motorsports machining an LS3 block and installing big bore sleeves.
This is an option for all Livernois Motorsports builds or customer supplied LS or Modular blocks. We do the big bore blocks for Ford for the Cobra Jet and also sleeve a lot of 3V blocks so you can do a 323ci aluminum big bore stroker.
Thanks for looking!
Regards,
Rick LeBlanc
redirelaP
IN
~~We do the big bore blocks for Ford for the Cobra Jet and also sleeve a lot of 3V blocks so you can do a 323ci aluminum big bore stroker.
Thanks for looking!
Regards,
Rick LeBlanc
Is this the process my 323ci Big Bore Stroker underwent?
I thought it started as a virgin block?
I emailed you this question along with another regarding my rearend several times but you and Andy were at car shows then the holidays hit. Are the cylinders sleeved like in the above video or treated bare aluminum ala virgin block? Thanks!
