07 procharger
Addicted to modding
Ive been tossing this around for some time now. I think im gonna pull the trigger but need some help.
Ive been looking at the 2.8 mammoth from kenne and I think im going to go with it, my only concern is how I build my engine for nitrous, will i be able to boost it?
Its the 9.6 cr livernois stroker, how many pounds can I run into this thig. also with it buing built "loose" for nitrous...will my ringlands hold?
Specs on engine build
Main bearings - .0022"
Rod Bearings - .0028" (coated bearings)
Piston to wall - .0035"
Ring end gap - top - .021" second - .025" (nitrous spec)
Rod small end - .0008"
Piston pin .0007"
Will my motor handle boost? if so how much with my clearences and compression ratio?
Thanks guys.
Piston pin .0007"
Thanks guys.
