You made your own phaser delete plates right 05Stroker? Did anyone ever find someone who makes them besides MMR? Has anyone confirmed that the V10 plates work on our heads and if so does anyone have a part#
I'm going to be replacing alot of the timing parts over the winter on my car and figure while I have the timing cover off I may as well delete the phasers.
Thanks!
will this work for you?
You made your own phaser delete plates right 05Stroker? Did anyone ever find someone who makes them besides MMR? Has anyone confirmed that the V10 plates work on our heads and if so does anyone have a part#?
Thanks!
I don't believe they retard 60 degrees...I believe it's 20 degrees in one direction and 40 in the other for a total of 60 degrees of adjustment. I just don't remember which gets which.
Ahh. So the VCT is technically retarding the cams from their normal position 60 degrees, but it's not 60 degrees from their neutral position.
As for the lockouts, I already have the livernois ones in but I'd like to be able to take those VCT controls out of the valve covers and the only way I could do that is by making those plates on. I may not do it but it's something I'm considering since I'll have the outside of the engine torn down over the winter.
Thanks for the great info! Are the gaskets you are talking about for behind the delete plates? I'm hoping to order all the parts I need this coming week so in the next few weeks I can start replacing my timing/valvetrain parts. The V10, is that considered a Ford or Lincoln engine?
As for the Paschal cam gears, I don't think I'm going to do them with my stock cams. In the future when I can get some money together for some custom grinds I'll probably do the cam gears then.
And these have the same flow lines as the 3v heads ?Hello Dysan
My name is Jeff and new to the forum however, I have been playing with modular motors for several years now.
The V10 solenoid delete plates will allow you to remove the solenoids. Engineering part numbers are 5C3E-6N881-AB and 53CE-6C743-AB. Any decent Ford parts person can x-ref these to catalog numbers. You will also need gaskets. Also the holes in the valve covers can be plugged with a freeze plug. I am doing the same to mine and actually ordered the parts yesterday. Cost was around $50.
Paul at Paschael Performance turned me on to this. I am using his adjustable cam gears on my 3v.
Hope this helps.
- Jeff
I would love a few pics of the flow lines on the back side of them when you receive them . I really hate to think I spent 12 hrs on something I can buy for $50.00.Can't see in the dark 1997 not 1977.
Are these the ford part #s you have , 5C3Z-6N881-AA and 5C3Z-6N881-BA ?You bet most likely next weekend. I can't tell you how many times I have reinvented the wheel myself. On the other hand people like you that aren't afraid and on the edge is what inspires us all.
Theses are the ford part 3s my parts guy said are the left and right for the ford engineering numbers you provided.
These are about $90 for both .
NOTE : I DO NOT KNOW THAT THESE WILL WORK OR NOT , JUST CHECKING INTO THE PARTS.
