sinabite
- Joined
- Jul 9, 2010
- Posts
- 210
- Reaction score
- 2
Tools needed, found at lowes
2 - 1/4" Hex Screws - $0.26
2- 5/16" Lock Nuts - $0.22
2 - 1/4" Lock Nuts - $0.22
1 - Piece of Galvanized slotted Metal - $4.39
1 - Bottle of Jose Cuervo Silver Tequilla - $35.00
First off you need to remove your grille. This is a very simple task that most of us already know about so I'm not going into detail on this one.
Next your going to grab up your slotted metal:
Then your going to cute two 8" pieces. Next your going to carefully make two bends in it. One approximatly 3" and then another approximately 1" and it will look as such:
After you have done this, it's time to grab those two 1/4" Hex screws and nuts. And mount your fog light on to the bracket. Be careful not to overtighten......it is metal against plastic and one of them will have to give eventually. I would also suggest not tightening the screw all the way so you can aim your lights later.
Next your going to crawl up under your car and look toward the front end of your car and find where the front end of your car is screwed together.....you should find two exposed screws pointing in toward the radiator.....those are the ones your going to use.
Next, take your fog light and it's bracket and place it on the top screw and secure it with your 1/4" lock nut.
Finally get out from under car your, carefully adjust your new fog lights, with one hand and tighten with the other. Reconnect your wires and wala!!
Now your probably saying to yourself.......but what about my grille? Why did I need tequilla for something that took 15 minutes??
Start drinking because here is where the REAL FUN begins.....look for it in my Next Post
