No. How do I do that?How did you verify voltage at the cop?
Damn. That sucks. Compression is exactly the same across both banks and all cylinders for me. It's a little low overall, but I think that is because of how the cams were ground (for the 20* lockouts) and the fact that I've switched to the 0* lockouts.I have fire and spark on that side so time for compression check......can't figure out anything else that would cause the drivers side to basically just act like its not firing at all.
I always hear this "cam 180 degree off" thing, but how often does this actually happen? I can't see how a cam could possibly be installed 180* off if you are at all trying to follow the instructions. Is it a simple thing to do? Wouldn't your compression suck ass? What were your compression test numbers?Actually going to do leak down instead we suspect the cam is 180 out. With 1@tdc 6 should be @tdc as well and have similar leak down. We suspect we will hear air on 6 coming out intake or exhaust [emoji35]
I've done that before. I don't normally put a plug in... I just rest the coil spring near something metal. A spare plug would probably be easier, though... lol.If y'all need to test for spark, all you have to do is pull the cop and leave it plugged in, then insert another plug and place the outside of the plug to metal. Then crank it over while someone is watching. It will spark. There are videos on YouTube of how to do this.
You will still build compression, yes, but if the cam gears/chains are uneven, you'll have different compression numbers.We did that even pulled rail and injectors had fuel on them. We either have a mystery wiring gremlin or cam timing issue we think. A compression check won't tell us to much if the timing events are off as it would still build compression.
Just make sure before you start taking it apart. I definitely wouldn't want to mess with the front cover until you've done that compression test.Gonna start taking it apart to fix next week [emoji35]. Basically mine was set up R and R vs R and L as the pic above
