My. $.02, I run a very small rear bar, smaller than most would run. It's a 1/2 inch bar, then I tune with springs and shocks. For the street i run 350-400lbs fronts with 200 rears. Front sway bar is 36mm Eibach set on stiff most of the time. At the track springs can be anything from 500 fronts and 300 rears to anything lower. The 1/2 inch bar keeps things tied together. The physics change with I completely remove it. I also have a 18mm and 20mm I take depending on how the track is feel on any given day. When I remove the RSB completely, it get a little squirrely, rear end jitters as it where. Even if i up the shock settings. I like the rear to be as soft as I can get it and still keep the balance.
