dmhines
KONA GT
I emailed Saleen the following question and wanted to get you guys input ...
I just bought a Saleen SuperShaker for my S197 Mustang.
I am installing a aftermarket Coolant tank in the empty space left from the AirBox Removal and won' be using the Saleen Supplied tank.
Is it possible to install the Water Pump on the Driver Side instead of the Passenger side? The main question is it OK to pump Water into the LOW INLET of the heat exchanger and have it come out the HIGH INLET of the heat exchanger. I have been told that other manufacturers do this so the coolant stays in the exchanger a little bit longer.
Do you see any issue with me setting it up this way? I was thinking of just flipping the exchanger to move the HIGH INLET to the drivers side but the brackets are not setup to do this easily.
Another Question ... is it important to have a specific port in the intercooler be the INLET or OUTLET ??? In your directions the driver side is the INLET and the Passenger side is the OUTLET. I would like to swap them since I'm moving the Coolant reservoir from the Passenger side to the Driver Side ..
