Where to attach my cherry picker?
Status
Not open for further replies.
Larryfishes53
Roseburg Oregon
My motor and transmission are ready to pull finally and I’m not sure where to attach my cherry picker. I’ve run a 2000lb strap under the motor @ the bell housing. Not sure where to attach in the front. Anyone?
ESP41
If you have a two post lift, it’s easier to drop it out of the bottom. If not, google 4.6 lift plate. I’ve “heard” that the 4.6 does not really have good exterior bolt holes to mount lift chains Without potential damage. That being said I never tried a top pull, so do not take that info as gospel.
whitmanink
denver pa
when i pulled my motor , i used the top 2 bellhousing bolts , and took off the alternator and used them two studs as lift points
Status
