Shaffe
that vid had to have tampered numbers. as cool as it would be that would seem massively underated. motortrends numbers seem more realistic, at around 435 flywheel HP i think they figured
It will never happen. Why? Because 7000 rpm in 5th gear (1:1) is 166 mph.
Care to explain? Perhaps a link?It can run on 87 but it does not make the rated 412hp its rated at like 385hp (or something close to that) on 87.
The 5.0 has seperate cams for intake and exhaust valves. Through the VCT system they use, the ecu can and does manipulate the compression ration of the valves. I'm not sure how low the valves can make the cr go but, the lower the compression ratio the lower the hp it will make. So, if you use 93 it should be able to run the advertised 11.? cr and to get more hp than on 87.
Cliff notes:
As I understand it, the ECU can manipulate the cr b/c of the 4 cams.
Not to play Devil's Advocate here but is that fair either, Mike? Car is not broken in, engine hasn't sealed yet, driveline is still tight.......I expect a car to be in my hands within the next week or so, It will be driven directly from the dealer, nearly off the truck, into my shop and directly on the dyno. In fact I may video the whole process as we are less than 1 mile from the dealership......and it may make good vid.
It was evolution performance not lethal. They don't have there car yet
Do you want absolute brand-frickin' new numbers or more "representative" numbers from a properly broken in car? Unless you plan to do that later anyway.
pretty sure someone already did a dyno in the correct gear with no problemI'm going to agree. with 3.31 gears, 7k rev, that puts the car at 166. However the computer governs the car to 140 something. Therefore you cant dyno the car in 5th.
