let me give you guys some food for thought...
Often times people are quick to blame the oil pump because it happens alot...but ponder this
did the pump break and cause the bearing material to come apart......
or
did the bearing go and the material went through the pump and broke it?
...for example an oiling issue ( say at launch where oil runs away from the pick up) and screw a bearing
I'll know for sure when I get the crank out and find out if a main is gone. If it is then it had an oiling issue.
but consider this....
the evacuation pump for the turbo has bearing material in the line. Thats the line that draws oil out of the turbo and returns it to the pan.
If the pump failed and broke first how did that material get there?
I'll also want to see the thrust bearing and the back of the oil pump to make sure the tranny did not force the thrust bearing/crank walk forward hitting the back of the oil pump case and shearing the gears. Excessive thrust from the tranny can do that.
Sounds like a good reason to have a relocated oil pump.
As far as I'm concerned the jury is still out on this. I still need to determine WHAT caused it.
or
