Bizzyb0nes
I have 2, brand new in the box 479v remotes, the fit the following alarm systems: 591xv, 690xv, 790xv791xv, cheapest I found them was amazon at $60 a piece new, I'd like to get rid of both for $75
to help you guys out, the programming is easy....
1. open the door
2. locate the valet switch
3. turn on the ignition
4. push the valet switch once, then push it a second time, but hold it
5. the alarm will chirp once...while still holding the valet switch, press the lock on the remote.
6. release both, then turn off the ignition, the alarm will make a longer chirp and youre all done.
