Why is mine the FEMALE?!?!!
Your's has the "Innie". I'm gonna take HER to work tomorrow and see how it goes. BTW, even in the local traffic it took all of 30 seconds to remember how much that clutch thingy sucks...
Ahh, the stock clutch in this thing is almost like an automatic anyway...took all of 30 seconds to remember how much that clutch thingy sucks...
...Oh and get it run like crap again and measure the voltage on the poles of the battery...
Oh well, then, it might suck indeed...Gonna check it right now. And BTW, not a stock clutch...
Because it's been such a bitch...Why is mine the FEMALE?!?!!
Are you running 60# injectors without tuning for them? You are kidding, right?Jerry made a base tune for my car with all the mods I have Except for the 60 lbs injectors installed. Will that cause a prob?
Voltages seem reasonable, so if it is a charging system issue, it is intermittent...It's wierd. Took the car to work today, 70 miles round-trip, not a single problem. Then I got home and started to back the car in the driveway and there she goes again. P0340 & P0345.
oh and what about those 60lb injectors without a tune?...
Let's hope so - what about the oil pressure? Has it been checked with something other than the "hey look at that, the car is running" ford gauge?I'm pretty sure that the loaded base n/a tune was set up for the current injectors/CMCV deletes/shorties. I won't swear by that for obvious reasons. Thanks for the input though...
eh, just hook it up to the tach - the ricers won't notice...LOL, I've been looking at the boost gauge but it doesn't do anything. Maybe because the ProCharger is in the trunk?
The way I left it there was a base tune in the car for as the car sat N/A with the ghetto fab induction setup.I'm pretty sure that the loaded base n/a tune was set up for the current injectors/CMCV deletes/shorties. I won't swear by that for obvious reasons. Thanks for the input though...
Tru dat, plus, I'm sure all that oil that made it's way in the alternator when the timing cover was leaking like mad dumping oil all over the belts didn't help it in any way.On a more serious note - given the notorious alternator bug and the tendency of the car to chew through a battery while sitting idle (and then burn up the alternator trying to charge it) - have you monitored the battery voltage to see if it is charging sanely?
P0345 is the cam sensor, but as Don pointed out - this has been a symptom of the charging system being FUBAR - so all the reference voltages drop and all break hells loose...
Another quality MAC product , got any pics?No oil leaks, the exhaust leak is fixed. There was a weld "missing" at the collector...
In addition to that, if need be, if you're still gonna make it down next week to ST then I may be able to swing by Thursday mid-day to do a base tune for the procharger setup so it's driveable down to ST. I'll be in Modesto in the morning and then headed to Reno after that.The way I left it there was a base tune in the car for as the car sat N/A with the ghetto fab induction setup.
Ted, did you try and load Jerry's tune? If you did then that's a big no-no, Jerry's tune isn't setup for those injectors nor that MAF location (with the way the induction is setup N/A with the combo of procharger piping).
