Looks very similar to what I saw in Brian's (DirtyDog) car before I tuned it.
#1 - The spark tables are not renormalized for higher than 100% load. This is basic stuff. This should be done on any blown car.
#2 - The Torque Table is less than stock. Obviously this is wrong, it should be raised much higher. This is not a novice mistake, as there are alot of people that do not seem to understand drive by wire yet, however, if you don't understand how the table works, then don't mess with it. Obviously don't reduce it less than stock, now that the car makes much more torque than stock.
#3 - Knock Sensor is basically off at WOT. I do this at times, but only on cars that have false knock. A stock car with a Whipple doesn't need this turned off. This alone may have saved your engine.
#4 - Default Load table looks really whacked, IMHO.
#5 - MAF Temperature Compensation is modified. He is surely not smart enough to change this table without lots of data that he doesn't have access to. Most people (me included) zero this out unless the car is stock (N/A)
#6 - The fuel tables are raped. There are alot of "tooners" that do this. The fuel table is where you command what you want the airfuel to be, and if the MAF is dialed in, that is what you get. Some people (like in this tune) commanded stupid airfuel ratios to get a result, for instance this tune is commanding 8.79 AFR at full throttle above 6500 RPM. Obviously this is wrong.
I am sure there is more wrong, but these are the few things that jumped out at me.
