Well over the winter I will be doing my full engine build. I am currently at 531rwhp/462rwtq with the following setup:
Paxton Novi 2200 w/ air to air intercooler-9.6psi
AFM powerpipe
KB BAP
39lb injectors
GT500 throttle body
DBX85 in a blow through configuration
Kooks LT headers & catted-h
Steede CMCV Delete Plugs
3.73 gears
Hurst Shifter
FRPP Stingers
Will be going to:
I had originally bought one of those Saleen 302 stroker kits but found that the pistons won't work so in my search for options I decided to go with the big bore Boss block, the 3.800 stroker crank, 5.850 rods and am having Diamond make some customs pistons to get me into the 9.5 to compression range. This combo will yield a 327ci stroker. I am using ARP top to bottom also will be using a GT500 oil pump.
I will be supplimenting this with the lethal triple pump returnless fuel system & 80lb injectors. I will also be running an AIS methanol injection kit with 1 nozzle before the blower and 2 after the MAF. I will be using a JPC intake manifold & COMP Stg. 2 blower cams. I haven't decided whether I am going to get heads or not.
I am going to see what the NOVI 2200 is capable of: Running an 18% IW balancer, GIJoe 8-rib conversion & 2.7" pulley. If my math is right I should be hitting the max blower RPM @ 6000 rpm. Actual boost will remain to be seen, too many variables especially with Denver altitude.
For now I will be running the stock 5speed with a Spec3+ until it breaks then I will most likely go to a built auto.
As far as goals this will still mostly see street time with a few trips to the track. Before I catch a ration of crap from the nay sayers, I love working on cars and I have the financial means to do what I love. Call it a dyno queen if you like, its the build I enjoy. The reality is after its done I will probably drive it for a few months then pull it back apart to build something else.
Pics of the current setup - I will add pics as the build progresses.
AFM powerpipe
KB BAP
39lb injectors
GT500 throttle body
3.73 gears
Hurst Shifter
FRPP Stingers
Will be going to:
