tmcolegr
It's All About the Build
Referring to I/C temps - not engine coolant temps.
Currently have a Canton battery box mounted I/C reservoir, Afco GT 500 Pro-Series Dual Pass Heat Exchanger w/dual Spal fans. Most likely will upgrade the stock Saleen I/C pump to a Meziere 20 GPM I/C pump. Already spoke to Meziere's Tech Support and they highly recommend this pump for this application. Also asked them about these pumps being noisy. Their response was "not if the pump is mounted properly as per our instructions and not run without coolant."
Reason for the upgrade: Per Saleen "The stock Saleen I/C pump is rated @ 317 GPH or 5.28 GPM. However the coolant flow through the entire I/C system (reservoir, pump, H/E, I/C & lines) is estimated to only be 1.5 to 2.0 GPM."
Planning on mounting the Meziere I/C pump in the same basic location as the stock Saleen I/C pump and utilizing the existing stock Saleen supplied I/C pump harness which now has been upgraded with JDM's relay pack w/remote switch.
Install to be documented with pictures along the way. Please feel free to chime in with all comments - negative or positive.
