interesting. i doubt it pumps more than that meziere does. That thing pumps so fast it could cut steel! My Rule Pump is just slightly slower, if not the same speed as the meziere. I think it pumps about 50GPM
ahh. I had the 55GPM IIRC
Saleen offers a larger H/E and I/C pump while retaining the original I/C core.
It will also prevent breaking the plug off the pump when you accidentally roll over a parking space curb thing......yea, I did that.
This should move the coolant faster through the I/C core, not allowing it to become super heated, but slow enough through the H/E core to allow efficient heat transfer.
What are you basing this off of?
Let me preface this by stating that I appreciate your efforts and the fact that you are sharing it all here.
I'm not an expert, but I believe you can move coolant too quickly through a system which doesn't allow enough time in the heat exchanger to efficiently expel all of the heat that the h/e is capable of. Why is the Saleen setup "too slow" and this setup "just right"? Or is that part of the suspense?
This is merely my opinion
What type of modifications did you have to do to wire this up? I'm assuming it's not plug and play.
