Mach1Marauder
LARGE MEMBER
Shouldn't you be knock free?
Especially with a lund tune.
Pretty much, but they are talking about an aggressive tune.
my 93 aggressive tune knocks a decent bit at WOT up around 5500, but in fairness I did my logging during 100F temps.
Its going to cool down next week, so I'll do it again.
I'm buying some VP100 Unleaded gas to mix in when I go to the track. Figure a few gallons of 100 to 93, should get me around 94-95'ish, which should at least ensure my minimum octane is 93 during these warmer months.
Dont do the "should get me" method. Do the math. 16 gallon tank right? So, figure 8 gallons of 93 and 8 gallons of 100(just as an example)
[(8 * 93) + (8 * 100)] / 16 = octane rating
744 + 800 / 16 = 96.5
so:
new octane rating is 96.5 octane.
16 is total gallons used.
Make sense?
With the knock you are getting couldn't you just go in and pull maybe 2 degrees of global timing? I noticed in my Lund tunes he leaves the global timing open so we can make adjustments.
the car will do it itself
Well I'm in Ky and it's hotter than the gates of hell here right now too. You think taking out 3 degrees would be too much? That's what I'm thinking about doing.
example, when i was trying out the new blower, i pulled 4 degrees of timing, car only ran 2 less than it was previously seeing, i added 2, it kept it where it was the previous run
assuming it's tuned correctly, it's going to adjust for you
Relying on the car to do it itself could be part of the reason #8's are popping.
when we added the new blower to the car, i did some datalogging on the track,
car went lean compared to where it was normally at, i needed to bump up base fuel pressure, the car pulled from 22 to 12 degrees of timing at wot to compensate for the knock
this is at around 750 rwhp
edit
upped base f/p by 10 psi, and timing and a/f went right back where it should be
edit
I don't feel its too much. I'm trying to negate the need to do it by ensuring there is a minimum octane level. I am thinking though no matter how much I run, I will still need to do a timing reduction until temperatures subside.
You've also melted down a motor. Maybe you should look at doing things a little differently.
The motor melt down wasn't a tuning issue. It was due to a faulty 02 extension that came with his headers. The car leaned way out in a pass and all went to hell from there. Terry is a pretty smart guy and knows what he's talking about.
