Mach1Marauder
LARGE MEMBER
when we added the new blower to the car, i did some datalogging on the track,
car went lean compared to where it was normally at, i needed to bump up base fuel pressure, the car pulled from 22 to 12 degrees of timing at wot to compensate for the knock
this is at around 750 rwhp
edit
upped base f/p by 10 psi, and timing and a/f went right back where it should be
Bump base fuel pressures.............
