Wheel and Tire Fitment - read here first.
1fast05
I wanna go fast
Gulfport Ms
I'll pull them off at work today to get a measurement and get back with you
18x12 with a 8-13/16" backspacing with 335/30/18 Bfg KDW's
I run a 1/4 inch spacers when I put my 345's on there because it'll rub the frame, other than that just cut the plastic cover off my rear shocks and it gives you another 3/4" to play with
ford20
White Plains,NY
It was brought to my attention that the tire sizing equation is off.
The total tire height in inches = [2(YY)(XXX)/254] + ZZ
using example above the tire height is = [2(40)(255)/254] + 19 = 27.02
Stock tire height is ~27" so you want to keep that in mind when looking at tire sizes.
It should be
The total tire height in inches = [2(.YY)(XXX)/254] + ZZ
using example above the tire height is = [2(.40)(255)/254] + 19 = 27.02
Can someone Check my Math for me to make sure I got this :idea: :dunce:
[2(102)/254] +19 =
[2102/254] + 19=
8.27 =19=
27.27
Still not working out for me. PEMDAS, parentheses exponents multiplication division addition subtraction. Thats the only way I can get it somewhere close to 27.02
peetiewonder
Terminator
SFV, CA
[2(102)/254] +19 =
[2102/254] + 19=
8.27 =19=
27.27
Let me look at that.... There was another error in the calculation. it should be 25.4 not 254 because 25.4mm = 1"
[2(.4)(255)/254] +19
[(.8)255/25.4] +19
[(.8)(~10)] +19 = 27
Sorry about the error
AJCrader
Glendale, AZ
I think I am either missing it, or its not there...What is the smallest diameter rim I could run on the rear of my '13...I am wanting as much sidewall as I can get for drag racing. I see reference to 17" rims but wasn't sure if I could go smaller.
peetiewonder
Terminator
SFV, CA
Not sure, but I think 15" wheels will fit the back of your car. That's just a guess. This guide was geared more toward street fitment.
Wile E. Coyote
Rio Rancho, NM
I just ordered and should be receiving Rohana RC10's, what does everyone think?
Wile E. Coyote
Rio Rancho, NM
I think you need to ask a more specific question in a thread other than this one.
Yes you are right I should have been more specific, I apologize. I am simply curious as to if anyone has an opinion of Rohana as a brand, I was unable to find out much about the company and "took a chance" on ordering the wheels. They will be 20x9 +25 and 20x10 +40.
Fosters
Just wanna add a link to a site i find useful when I look for this kind of stuff (like meow).
http://www.willtheyfit.com/
It's kind of what the excel spreadsheet mentioned by the OP does, except online and without excel. Bookmark it, use it, love it. :beerchug2:
TRC51
NOTE TO OP:
The spreadsheet at the bottom of your original post has gone missing. I used that a lot, so I went searching and think I found a very nice replacement. This shows measurement differences and everything!
http://www.rimsntires.com/specspro.jsp
Redneck_Racer
Ohio
Hello. It’s time for me to get tires, wondering if I can run a P285/40R18 on all four corners of my 05 GT? It has stock suspension.
Pretty sure it’s been done and discussed. U need the correct rim size and offset to work. Search for that size and I’m certain there are threads on it.
