Sway Bar Relocation Install and New Dash
bigpappy33
11.17@126
Ft. Lauderdale, FL
Today I decided to do my swaybar relocation to fit my 15x10 Racestar wheels I do not yet have (supposed to be shipping next week).
It was a pretty straight forward install, I was a little worried about the BMR LCA relocation brackets and my thicker Steeda rear sway bar, but they fit together fine. Grinding was easy with a cutting wheel, just alot of sparks which was annoying.
Here are some pics after I finished. I had to notch the Koni shocks to get it to line up after the brackets were installed, my only gripe with the kit. I sprayed some rustoleum over the bare metal too so it doesn't rust, especially on the shock. Too bad I didn't get yellow paint :X lol.
Also installed a GT500 dash to replace my silver IUP dash and finish up the interior for now.
Sorry for the shitty cell pics! I'll take better ones eventually.
GeorgeInNePa
Clarks Summit, PA
Wouldn't it have been better to put the bolt head under the shock eyelet? You could have even ground down the head a touch if you had to.
bigpappy33
11.17@126
Ft. Lauderdale, FL
It would have been, but the bolt head was about the same size. That was the nut that you see in the pictures on the shock side... so there would have been something in the way regardless. In hindsight I should have tried it, but I was having too much fun with the grinder.
