Bmr k-member and stock oil pan
james432
east moline IL
Okay do i need to raise the motor up to get the stock oil pan out with a bmr k-member?i just got the car out and seen a oil spot got under the car and oil is around the hole edge of the pan..looked all over did not see anything leaking from up top..thanks
skwerl
tree hugger
central Florida
Been a while but yes, I believe so. Just unbolt the 2 motor mounts and raise it up slightly. No need to disconnect the transmission.
skwerl
tree hugger
central Florida
Yes, on my 2009 Bullitt. It was much easier than with the stock K member. Lots more room to work.
07 Boss
Sin City
Have you tried to just tighten the bolts? That would be my first step.
james432
east moline IL
No haven't messed with it too much i was going to try that frist though.iam going to get under there maybe tonight or tomarrow
