Kaldar142
With all due respect, that's hogwash. It is still in front of the center of gravity, so it's not "neutral". Losing weight anywhere is a good thing. And if you can't lose it, then shifting it to the rear is better than having it in front of the firewall.
I agree, anything to help balance out the front to rear weight balance.
although the stock location is still much better than most cars, my subaru it was right in the way front of the car behind the headlight... (wtf??)
Thats awesome. You havent had problems with the car? Electronics stuff works fine? Cranking ok?
cranks better than it did with the stock battery actually.
electronics work fine but i dont have anything fancy, just stock stereo system.
the only thing i notice that is different is that my idle fluxates when i initially clutch in (dips to around 550, back to 700, back down to 550 then stabalizes around 800)
i don't know if that happened before, maybe i just noticed it now... i'm going to try raising the idle.
i just put it in though, so we'll see... only guys i see using this battery are typically hondas, evos and subarus.
hopefully it will work out well, if not it was only $60.
