Five Oh Brian
Mustang Guru
holy old thread batman! lol
Yes, old thread, but I've learned the hard way around here to use the "search" feature and to not start my own new threads.
Stock has been doing hell of a good job for me since I made this thread o so long ago
Im glad these helped you . I added the MSD coils for the same issue . Whatever the real issue was at the time the MSD COPs solved it , but I would assume now that they were just making up for some tuning issues at the time . Many have gone allot further then you and I on the stock COPs. Whatever works I guess .Stock wasn't cutting it for me with the blower. Spark blowout was a real issue with the blower. Not only does my car run silky smooth now, but initial tip in feels noticably more powerful (almost like the feeling when you add several degrees of timing) and the stumble/hesitation always drove me crazy so I'm so glad the hotter coils cured that!
I trust you can get away with the stock coils since you're still NA.
I had serious spark blowout when I installed my Vortech blower a few years ago. Switching from the factory spark plugs to copper/colder FRPP 3V0's really helped, but there was always a hint of spark blowout in extreme situations and the car was never silky smooth. Still enough to run an 11.85 @ 113+, but not factory, silky smooth.
Fast forward to now. I decided to try hotter coils and just installed the GMS "hot street" coils. They aren't terribly expensive ($250), so I figured it couldn't hurt to try and I have the stock coils just in case. They are rated to produce 45K volts vs the stock coils rating of 20K volts.
I gotta tell you that the car runs silky smooth now! Excellent tip in with no hesitation like I always had with the blower & factory coils. I've gotta get to our local dyno and dragstrip to see if there's any more power being made, but just having the car run smoother (and a noticable improvement in fuel economy) is enough of a plus for the minimal money spent.
If GMS had problems in the past, I believe they may have fixed them. So far, color me happy with this mod.
Not to bust your bubble, but unless the aftermarket COPs show lower resistance AND more inductance, they ain't better. Fatter wires on both the primary and secondary, and more windings on the secondary are what you want.
I am glad it is running better for you.
Increased voltage does nothing for spark energy. Increased current flow, does since the energy in a coil directly related to the current squared!
HTH
Mike
I don't care one bit about the science of it all.
Well this is certainly the wrong forum for you.
Mike
Gents,
Excuse my ignorance on the subject, but when datalogging a run what indicators/parameters do you look for to determine spark blowout?
My problem with the a/m COP was that they miss at low speeds under load . Never really tried to see if it was working at high boost up top. The fact that they were missing at part throttle at low speeds was enough for me to go back to Stock COP .
Now Im having a little bit of an issue with blowout at 840 rwhp . Cylinder pressure is high especially with stock heads and cam . My only solution was either go with ported heads , or better spark by either A/M COP or a KB BAS.
I installed a BAS but really haven't done any real testing b/c the weather has been crap. Hopefully Ill have some data for everyone this week . If no more blowout expect Me to turn up the boost to 27 psi's .
Pete
You are at .45 gap on a s/c car? WOW!
Brian what was your ET stock vs gms and the different gapping.
