Norm Peterson
corner barstool sitter
Edit - never mind
Norm
Norm
It's probably time to come up on spring and dampers both. But remember that one of your goals at the time with the setup was that it was comfortable on the street. Well, KW's are pretty comfy considering what you've now grown into wanting. Give you the higher rates you are after, and independent double adjustment too.... plus that nice lifetime warranty and the ability to cornerweight the car too.
Well right now I see two glaring issues beyond overall grip in the car. The first is the lack of throttle oversteer without upsetting the chassis.
Right now, trick shocks and super stiff springs are an absolutely low priority.
It's genuinely a shame that you had problems with your car and Ford wouldn't or couldn't take care of you. One of the many reasons I always recommend avoiding 1st model year cars or when they make large changes in the drivetrain.
A little birdy told me that your FRS/BRZ (I can't remember which you bought) might be getting prepped for Autocross duty instead of the Vette? I'm not sure I put much faith in that little birdy as he drives an Evo. That is always exciting! I do hope you return to the Pony Cars someday!
My FR-S is my daily driver. It's got ST parts on it, and I'm going to screw around with it in St Louis in a few weeks *IF* that event happens, but it's FAR from a full build. Not sure I will do a full tilt build on it, it is my means to get around and I don't want to make it suck for that.
I just traded my Z06 on a Grand Sport because I've learned (or rather confirmed) that the gearing just can't be overcome with a C6 Z06. I'm pretty committed to Corvette for right now. But I always think about an ESP S197. I drove one I setup two weeks ago, first run outran any run I put down in the Corvette. And when ESP is on (meaning Mark Madarash, Dave Ogburn in my old Camaro, and myself because we've each done this, nobody else has) it can outrun SS.
My thoughts are these:
Fixing the handling so you like how the car drives should be your first step. Since you're not ready to lighten your wallet for big $ shocks and stiff springs, just raise your rear roll center until the car becomes a bit loose, then adjust the rear bar until you're happy.
A better diff will help if yours is shot, but rebuilding the stock one is cheap and easy, and can easily last a season with multiple drivers, assuming those drivers know enough not to plant their right foot if they get one wheel peel. A torsen style diff will change the handling somewhat, loosening the car up more with power application.
Dropping a few pounds will help, but only a little. I used to take passengers regularly when I autocrossed, and a 200 lb passenger in my sub 3000 lb SM Mustang would slow me down somewhere around half a second on a ~60 second course. It'll make less difference in a heavier car.
If you're willing to drive far enough, you can get in some more events this winter. No idea how far that would be for you- when I was heavy into autocrossing, I used to drive 250+ miles one way for winter events. Coming home often got interesting.
Justin
All else equal, something like 3/4 second per minute. No idea what the compound change might add beyond that.
I try to keep up with the smart kids but I'm just a weldor.[width ratio]^0.15.
Street Touring Ultra (STU)
AudiMustang (over 5.0L)
S4
BMW
135i
3 Series (E90 chassis, incl. M3)
(2006-10)
M3 (E36 chassis) (1995-99)
M3 (E46 chassis) (2000-05)
Chevrolet
Camaro (over 5.0L)
Ford
Are you legal in STU being under 5.0?
Plus, those damn STIs.....
I don't run with passengers when I have actual competition showing up and at this previous event I had zero passengers because I actually had a competitor (prepped [according to the owner] Integra Type R which I narrowly beat) worth running against. I've in the past taken rides on the first run but rarely after that.
Hey Whiskey, I didn't mean to say you run with passengers, I was just trying to give you an idea about the time savings from dropping weight. It helps, but once you get beyond the wheels and heavy stock seats the $/second gets very expensive.
Justin
Fair discussed the STU versus STX issue in his blog (or whatever), and he seemed to indicate that the time saved by adding wider tires (which they tested) would not be enough to make it any more competitive than it was in STX. I am not sure why the SCCA decided that the car has to be in one or the other, leaving it in both would do nothing to upset the apple cart in terms of the current competitive cars in each class.
