Grabber Blue 5.0
- Joined
- May 21, 2011
- Posts
- 1,420
- Reaction score
- 141
A converter is a must for what you're trying to do. I would have done that long before the Boss intake.
My best is an 11.81 but that was last Fall. This weekend all I could muster was an 12.2. I run the stock converter and stock 3.15's. This Winter I'm not going to screw around anymore. I'll be putting in a Circle D.What does your car run, GrabberBlue?
I think you'll have little luck running the Boss intake with stock gears and stock converter. Good luck with whatever you do.
It sounds like you are suggesting that a gear swap (which might go 1.8x 60') will give me traction issues, while a tc swap (which should go 1.6x) won't? That makes no sense. Maybe I misinterpreted.If you go to 3.73s even with the stock tc you will have troubles with traction. I went to 3.73s and gained 0 from 60 to the 1320. A local guy experimented with the stocker and boss with different mods. The boss cost a tenth with the stock tc and gained a tenth with a circle d. Each day of testing was the same day he would switch intakes. Just save your money for a tc.
Did you swap gears before or after the torque converter install? I've read that if you already have a tc, gears do pretty much nothing.
The best gains to be had are with the TQ converter.
I think we've established that, and I'm not arguing that. I can get a set of gears, with install cost, for about $300, vs the $1500-$1600 installed cost of the converter. Obviously the gear swap won't help as much, but I find it hard to believe that it doesn't help at leat a little with a stock-converter Boss intake setup. But if it really won't help, I won't bother.
Also, I only go to the track 3 or 4 times a year, and I don't run drag radials on the street with this car because I drive it so much in various summer weather conditions, so I'm guessing that with a good converter I'll be just blowing the tires off on the street.
I'm planning on heading to Rock Falls on September 7th. Let's go!
3.31 will be perfect to cross the stripe at the top of third.
Maybe, if the weather is cool enough. I'm anxious to get back out there!
Thanks. Actually I think it will be close with my little 26" tires and my 3.15s. We will see. On average-DA days when the car traps 116 it should have plenty of room but if we get a really good air day and the car maybe goes 118(?) it will be close.
When I ran my 12.26 at 116 a month or so ago it did it with 6800 shift points that had the car shifting into 4th at about the 1000' mark (or maybe even earlier)...not ideal. Hopefully the 7700 limiter I have now will be ideal for flying through at the top of 3rd with good power still from the Boss intake.
Offroad X-pipe is on the car now. Haven't driven it yet though.
Well I'm getting a Circle D converter ASAP. Should be perfect with my Boss manifold, 26" tire, stock gear, NA setup. I can't wait! I'm going to the track this Saturday with the stock converter to see what does, then a couple weeks later with the Circle D 5C.
