Need help choosing between Comp cams 127200 and Detroit Rockers.
Jerry Stoneking
Detroit Rocker Naturally VS Comp Cam 127200. Anybody have some good info when I comes to pick one of the two.
I have a JLT cold air intake, JBA long tubes, catless, Exedy Stage 1 clutch, 4:10 gears. I want the most power and torque, sound is not as important, I don't want to change springs (but would), and don't want to limit cam phasers. Which cam has the most area under the curve.
Jerry Stoneking
A word from Lito:
Hi Jerry, the 200s (and the 300s but this require springs, etc.) will have better performance than any of the cosmetics (Hot Rods, Detroit's, Rattlers, Thumprs...)
Every cam would usually move the powerband up in the RPM range, that is how make gains but the cosmetics tend to be worse at low RPM.
If lope is not that important for you, any of those other two would work great.
There is also a bigger performer still is the 500s which will lope and the gains are even better up top, is probable the best all around cam for these cars.
