Tbone
Its a tough call for me. Been thinking about it more and pros and cons of each for my application.
Whipple pros: can get a used kit for about 4k, easy install, Cons: Lose my shaker hood which I really like, and it has its little upgrades too, tensioner, 8 rib pulleys etc. have to deal with belt slip. Can also get long tube headers which I am not sure is a pro or con (more hp, but more money also)
On3 pros: Out the door at 4k also it sounds like, but new system. Can keep my shaker hood, money saved as I dont need long tubes ever. Cons: Harder install, seems to have a tons more parts (which means more parts to fail in the system), added things needed (new bov, wastegate, turbo itself) and all the little upgrades people seem to run such as boost controllers etc. May run into issues with ground clearance (Im dropped 2 inches).
So any guys who are reading this with a near stock mustang, figure out your FI early and make it one of your first mods if possible or build around it. It affects too many parts. Going turbo or SC affects so many parts, intake, shakers, exhaust, gearing and even suspension may give you issues down the road. If I get LT headers thatll rule out turbo . If I turbo I lose my shaker and the install is much more complicated and my car is really low so may have clearance issues. SC is quite expensive less I get a used kit. Also I would like to get cams this winter, but dont want to buy NA cams as Ill be going FI soon.
If I could start over Id have built a mod road map for my car. Either FI I could get 3.73 gears and delete plates and do suspension mods such as LCAs etc. SC I would also have gotten LTs and hpipe done and skipped the shaker. Turbo I would leave the exhaust as is other than axle backs and would have gotten more a conservative lowering package. Could also get UDPs.
Plan ahead people!
Plan ahead people!
