Gray Ghost GT
Road Racing Fanatic!
My 2009 Mustang GT arrived at JDM Engineering in New Jersey for a significant upgrade - the 302E forged stroker shortblock!
Here's a list of all the "goodies" going in over the next several weeks:
Brakes, Suspension and Cooling:
Jim Jr., good meeting you at JDM and taking the time to review all the details supporting this project. I appreciate your technical recommendations and patience in answering all my questions over the past several weeks. Mike
- New FRPP Aluminator block #M-6010-A46NA: Plate hones for a truer bore geometry
- Speed Pro NASCAR bearings
- JDM Spec ring pack with Moly top rings for better seal and longevity
- JDM Spec Custom Forged Manley Pistons
- Manley Forged Steel 4340 Connecting Rods with ARP Fasteners
- JDM Spec Kellogg Forged Steel Crankshaft
- Induction Hardened Journals and 8 Bolt Flange
- ATI 15% Dampner Pulley
- 3V Cam Adjuster
- FRPP 39 lbs Fuel Injectors (new style)
- Shelby Oil Pump O-Ringed with TSS Billet Gears
- Moroso Oil Pan #20548 with Windage Tray #22933
- Ford Racing CNC Ported Cylinder Heads #M-6049/6050-N3VPA
- JDM Custom Grind Comp Cams
- PAC 1233 Valve Springs
- Ford Racing Laser Etched Black Valve Covers
- JPC Braided Clutch Line Kit
- Exedy Mach 500 Stage 3 Clutch
- SPEC Billet Steel Flywheel
- New OEM Battery
- Wilwood Superlite SL6/SL4 BBK with Wilwood Brake Flexline Kits
- Vogtland 1.2" Sport Springs
- Maximum Motorsports Caster/Camber Plates
- Steeda Sport Sway Bars with billet end links
- Koni Yellow Sport Adjustable Front /Rear Struts & Shocks
- Cervini Type III Chin Spoiler Textured Black
- Steeda X5 Ball Joint & Bumpsteer Kit
- BMR Lower Control Arms with poly bushings
- Steeda Adjustable Upper Comp/Street Kit w/ HD Mount
- Agent 47 High Flow Lower Grill and Agent 47 Cooling Kit
- Carbotech Brake Pads XP12 – Front XP10 - Rear
- Fays2 F2S Watts Link
- Griggs Racing Power Steering Cooler
- Fluidyne Aluminum Radiator
- Taylor Battery Relocation Kit - NHRA Approved (Trunk)
- APR Performance Carbon Fiber Adjustable Rear Wing GTC-200
- BBK Twin 62mm Throttle Body
- 2008 OEM Intake Manifold with Steeda Billet CMDPs
- American Racing 1 5/8" LT Headers with Catted X-pipe
- Bassani Stainless Steel 2.5" Race Exhaust
- Ford Racing Gears 3.55
- Spydershaft 4.0” Aluminum Driveshaft
- Steeda Lightweight Radiator Support
- MGW Shifter 3650 and Roush Billet Shift Knob w/ Grips
- Moroso Radiator Expansion tank
- S.O.S. Triple Pillar Pod with Auto Meter Gauges
- Raptor Shift Light (Black with Red LED)
- Ford Racing Rear Differential Cover
- Torsen T2R 8.8" 31 Spline LSD
- Front and Rear Tow Hooks (Recovery)
~~ BEFORE ~~~
I'm looking forward to the AFTER performance results on the track at VIR in 2013!!!
