ok...no pics, but i did test fit the wheels. the rears for sure need NO spacer. the fronts i was able to make work with a 1/4" spacer. i did not need a 3/8". so it saved some of the threads on lugs.
Do you need to use tubes for a 27 or 28 inch et street on these 15's???
Stock studs are 3" long.
anyone try the summit drag stars.little bit cheaper and look the same.just curious.
Any word on the build date that got the revised calipers? .. or anyone with a 2007+ that has tried the rears?
Duh... what was I thinking? My new Moroso studs were 3" long, not the sotckers. My bad.stock ones are actually 2.25"
Did you get my reply???
Actually, they have a 0.594" knurl. The hubs had to be drilled out.So you got Moroso studs with the .549 knurl size? Cuz I'd switch mine out if I could find some 3" long instead of 3.315".
Nope. I got the reply that he was going to try them out but I never got any answer on what happened .. at least I didn't see it.
http://store.summitracing.com/partdetail.asp?autofilter=1&part=MOR-46185&N=0&autoview=sku
That was 3 years ago... I don't know if anything new is on the market now.Figures. Couldn't possibly be that easy.
