- Joined
- Oct 23, 2007
- Posts
- 307
- Reaction score
- 0
The Jegs 15x8 being used actually has 5.5" BS, not 4.5". As mentioned, to not stick out, the 15x10 would need a BS of 7.5", to have a chance of fitting.
2 questions.
will the 15x8 with 4.5" bs fit on the front? Id like to use these on the street.
Also, jegs makes a 15x10 with 6.5bs. The outside lip should not stick out cuz its the same as a 15x8 with 4.5bs. The extra 2 inches in on the inside edge. I gather that you guys say the 10 inch rim wont fit. Why?
Just swapped out the front wheel studs. The stock ones are actually 2.25" vs 3.315" for the new ones. I'm not sure the lug nuts I ordered are gonna be long enough for my street wheels. And I probably won't get to try them out tomorrow. I'll be in Pomona all day at the swapmeet.
As far as the wheels, he's got the wheel specs and part numbers on post 1.black05stxjt,
Can you please sum this up and post part# for the rims and tires and total cost?
thanks
No one else has tried that option to my knowledge.So what about my other question. Will the 15x8 fit on the front if i were to want to make these my street wheels?
15x8 Jegs will NOT fit the front - Caliper is way too big - You could NOT grind it down enough.. I tried too
Bummer. I wonder if theres a 17" option that looks good with the 15 in the rear.
Why anyone would pay that much for a 17" wheel is beyond me...Weld makes a 17" Aluma Star but hold on to your wallet !!!
http://store.summitracing.com/egnse...204&searchinresults=false&N=700+115&y=14&x=30
i relaly wanna hear what happens with 15x10s. And i really DONT want V6 brakes.
for the record, i did a little snooping. Weld prostars also make a late model f body wheel. 15x10 7.5bs 5x4.75. They look like they could be drilled for us. Anyone wanna call?
