Event write-up Five Star Ford at ECR, June 29, 2013
In the section above I talk about the 2013 GT Tests 1 through 3, with the 3rd test being done at a June 29th 2013 event. I drove two other cars that day, and we worked on many more, so I will do a quick event write-up. As I've said before, the 2.7 mile course at ECR is a
brake killer, and when it is approaching 100 degrees it only gets worse. But we love ECR as a test track on Mustangs because it has a lot of tight corners, bumpy surfaces, and these brutal braking zones. There are also some decently long straights to take advantage of power.
We had both our 2011 GT (Amy in the red) and 2013 GT (Terry in the black) out running at this event. We took riders all day.
I noticed several things after driving both the '11 and '13 GT's that day. One, while the extra 50 whp from the modified exhaust/tune/cold air on the 2011 GT makes the car a little louder and more fun, the added power isn't a HUGE improvement. The stock powered '13 GT 5.0 could hold its own on the straights with virtually any car out there. Both cars had very high end monotube adjustable coilover dampers (Moton doubles with remotes on the '11, AST doubles with remotes on the '13), so the bumpy nature of this track upset neither car. And after adding the same 14" Brembo front brakes, ducting and Carbotech XP20 front pads to the '13 GT as the '11 GT, they both braked VERY well, lap after lap after lap.
No, the biggest difference between the cars was
grip.
Obviously, the '11 GT has wider wheels (12" vs 10" wide) and tires (315/30/18 R-compounds vs 295/35/18 streets), and a much softer tire compound (Hoosier R6 vs Nitto NT-05) than the '13 GT. This made for different driving lines and speeds in corners, but almost identical brake marker choices. The Turn 3-4-5 complex as well as the Turn 7-8-9-10 sequence were MUCH slower in the black '13 GT on 200 treadwear street tires than in the '11 GT on big sticky Hoosiers. In the end we only saw about 4 seconds difference in the fastest lap times from each car that day, and it was all in the turns. But, and this is important, the '13 GT could only do one TOP SPEED 10/10ths lap in a row, due to rear tire overheating. The brakes could go all session, finally, but the
street tires would only make it for one very hard lap before they got so hot the rears would start slipping and sliding like mad. And this is even with +60mm more tire than stock at each corner.
Video from the Eagles Canyon Track Day ~ Hosted by Sam Pack Ford. Video by Ben Freedman
Again, I'm kinda hard on tires
and brakes, and aggressively use the throttle, so I might be more prone to rear tire overheating than some in Mustangs. The '11 GT could just pound out lap after lap at the 2 minute mark or quicker, with the Hoosier R6 tires. It was easy to keep going and going at full tilt, as long as you didn't get stuck in traffic.
ECR Photo Gallery: http://vorshlag.smugmug.com/Racing-Events/Five-Star-Ford-ECR-062913/
I did notice the '13 GT run a bit on the warm side, late in the day. We haven't seen overheating in our 2011 GT at all, even running it for the past three years in all sorts of hot weather events (up to 105°F). But last weekend in my 2013 GT it got up
past mid-way on the stock temp gauge, to 3/4 and almost to the "H"... first time we noticed that. This was after 6-7 hard laps (15 minutes) in the last session of the day when it crept up to 99°F. The only difference in our two Mustangs is the grill... the '11 GT has no foglights and the '13 GT still has them in place. Both have completely stock cooling systems, and none of the extra coolers that come on the Boss302 or Track Pack cars. Strange. Only did it once, and after half a lap it cooled off back to normal. Never had a check engine light or loss in power, just saw it creeping up and I cooled it off. I dunno... if I was going to keep this car the fog lights would come out next to hopefully improve radiator air flow.
I had a blast driving Dave B's GTS3 BMW, too (below, right). This was formerly the gold 4-door 325i called "Goldmember" back in the day, which I helped him flare and stick 18x10" wheels with 285mm tires onto. Dave worked on the GRM E30 for a year as well. This car has come a long way and it is now gutted, caged, with an S50 motor, and he's raced in NASA GTS several times with some wins. The car was built on a tight budget, but is still fast and fun. He wanted me to take a session in it, so I climbed in, knees hitting the dash, and managed about 6 laps before I brought it in. Lots of grip, no,
mountains of grip! Those 285mm R compounds on a sub 2500 pound car WORK.
We tracked down a few issues and I told Dave I'd come out and help him debug some things at another ECR test, which I did on
July 13th. I got out there with all of my test gear, sitting on pit wall, timers going, 7:30 am, he's making a warm up lap... and of course the car broke (camshaft) on his first test lap - dumb luck. Oh well, we'll do it again soon and help him get more speed out of this car. It should run 2 minute flat times once it is sorted; he played lead-follow with me in the 2013 GT and he could keep up.
I've still never driven a '11-up GT on track with the base model 18x8" wheels and 235mm All Season tires (above left). I suspect it would be quite hilarious, but probably very frustrating after a lap or two. These tall 18" all seasons are nice for the street, but you can NOT use the gas pedal much or the rear will spin for days. I've tried in our 2013 GT on the street, but they are devoid of any usable grip. These particular wheels no longer fit over the 14" front brakes, so they are of no use to me on the 2013 GT. I'm still amazed that Ford would put a 420 hp motor in these cars and allow the base model GT to come with such skinny, crappy, low grip tires. The 13.2" brakes are also pretty much crap, and won't last two laps of hard use on a track like ECR. As I tell anyone that will listen, the MOST important option to get when ordering or looking for a '11-14 GT is the BREMBO BRAKE OPTION. This is the best bang-per-buck option on the best bang-per-buck model Mustang ever made. It only only takes you from a 13.2" front rotor with craptastic sliding 2-piston calipers to the 4-piston fixed Bembos and 14" rotors, but it nets you a one inch wider wheel as well. True, it is a 19" wheel, which is really only done for styling purposes, but at least it comes with a 255mm tire.
Again, if you purchased a '11-14 GT with the smaller brakes, we've got that covered plus more in our Vorshlag 14" Brembo Upgrade Kit. Hugely important if you ever track your '05-14 Mustang and it came with the small stuff. I mention this again because we had some good examples of how
bad the smaller 13.2" Mustang brakes are that weekend at ECR, with one fellow getting all of
ONE hot lap before he called it a day. It took one lap for the fluid to boil, the brake pedal went to the floor, and off the track they went. Weee! We've since hooked him up with some proper fluid and Carbotech pads, and he's heading back out on track, but the 14" Brembo front brakes are on his wish list, and brake ducting won't be far behind.
The base GT's 13.2" front brakes are better suited to drag racing or autocross, not track use.
Ryan was there at this ECR event with me and Amy and he worked his butt off all day long. There were a lot of noobs at this event, driving new but mostly bone stock Mustangs, and some EVO and BMW guys, too. Even with instructors slowing them down, several of the new guys ran out of brakes in one or two sessions. Luckily we brought a lot of tools, a generator and an air compressor. We ended up doing full Motul RBF600 brake fluid flushes on several cars, one guy fried his pads, swapped some wheels for people, changed camber on multiple cars, diagnosed weird sounds and shimmies in half a dozen cars, and basically Ryan was wrenching all day long - he never even made it to pit wall to work on our two cars. Most of the work was on brakes.
In the first session of the day, a student asked one of the experienced instructors to take a few laps in his 2012 Mustang GT (non-Brembo car). The instructor took a warm up lap (driving 5/10ths), then sped it up a little on the beginning of lap 2 (7/10ths) and drove right off the end of the hardest braking zone corner. He was shocked - "Man, I was barely pushing the car, didn't have two laps on it yet. It just lost the brakes
completely!!! Pedal went to mush, I was pumping the brakes but nothing was happening."
Been there, done that. We looked at the car and both the fluid was boiled and the front pads were gone, turned to goo. Luckily no damage was done other than to ego. Student was really bummed, as he got ZERO laps himself (they gave him credit for a track day the next weekend). We brought spare track pads for S197s, but didn't have them for the non-Brembo front calipers in our trailer, so he called it a day very early. Amy saw him in the paddock later, all bummed out with no brakes left, and she stuck him in the passenger seat of our 2011 GT. After a session riding with me in the 2011 GT we
turned his frown upside down. He was so pumped when he got out of the passenger seat - hooked for life! He came by later the next week, picked up some Carbotechs and Motul from us, and I gave him some barely used 13.2" front rotors, and he was back at the track the next weekend - with no problems.
So the moral is - don't underestimate the basics. S197 Mustangs come with "low rent" brake consumables from the factory: the stock
brake fluid and stock
brake pads are really for street use ONLY. Even noobs can ruin the old/stock fluid quickly. Sure, some new students are rolling around so slowly that their brakes
might make it the day, totally depends on how hard they push it. I seem to find the weak link in any cars' braking systems very quickly, and apparently so do some other instructors. It doesn't take much to really need front brake ducting on these cars, too.
Time To Sell The 2013 GT
As much as it pains me to do this, it is time to let this car go to a new home, and it is now
for sale. We recently saw the extremely delayed ruling on the Watts Link/Diff Cover change for SCCA ESP class (a simple rule tweak took 8 months to write + 1 or maybe even 2 more years to implement?) and now it might not take effect until 2015? Basically this demonstrates that they don't care about Mustang owners with these needlessly slow rulings - delaying the "rules fix" to make the majority of the off-the-shelf Watts Link systems legal until after 2015. Progress within this club is painfully SLOW and frustrating. I'm not sitting on this 2013 GT for another year or TWO just so the rules makers pull their heads out of their back sides, so the dedicated ESP build we originally purchased this car has been aborted.
Vorshlag 2013 GT is FOR SALE. See more here.
Still, buying this car wasn't a waste. We got some testing done, logging good track data in wheel/tire changes, camber plates, shock/spring upgrades and brake upgrades. We developed a few unique to '13-14 parts, and made somebody a really cool track/street car, but for the most part I lost a lot of time and money on this car purchase. I won't forget this one for a while, and will think very hard about it before I build another car around SCCA Solo class rules again. Lesson learned.
Left: This is the lightest stock 2011-14 GT we have ever weighed. Right: Not much room left in my home garage to park this one
We have added a few more mods to the car since the 3rd track test day in June. We had previously installed a Spohn "Del-sphere" Adjustable Panhard Bar to this car but it just made too much noise on the street, so I had the guys yank that piece out and install a Whiteline Adjustable Panhard Bar instead. Ahh.... quiet and effective. While they were under there, I had them add Whiteline LCA Relocation Brackets too. These brackets improve the rear geometry for cars lowered like this, and makes it better for street, track and dragstrip use. This black on black 6-spd car is absolutely spotless inside and out and has 5100 miles.
It has AST double adjustable coilovers with remotes ($5000), WL Panhard Bar and LCA brackets, Vorshlag camber plates, D-Force 18x10" wheels, 295mm Nitto NT05's, 14" Brembos, Vorshlag brake ducting and SS brake lines, all synthetic fluids, and plenty of custom care done by the Vorshlag techs. Details like the Seals-It 2-piece grommets in the trunk for the reservoir pass-throughs, custom reservoir mounts, and more. A lot of car for the price - see the
For Sale page for more details (please don't post questions in this thread - PM me or e-mail us at
[email protected]).
If the price is still shown on the linked
for sale page, then this car is still for sale. If not, it is sold. Somebody is going to get a killer street/track car for a great price. We showed it at the last Dallas Cars and Coffee event and had some bites, and I suspect it won't last long. Again - I'm losing a lot selling it at this price, but having two track S197s right now doesn't make sense. We've got so many project cars being built and this 2013 GT is now just a distraction. If you want to come by and look at the car, please call Vorshlag a day before, so I can bring it to the shop from my home garage.
Cheers,
