Wow!!!
Car showed up on the 10th NOT the 3rd and was supposed to ready for the dyno. Lets see..the 10th,minus the date of this thread is..7 working days/11 days. The car wasn't even dyno ready. Got a couple of issues worked out on the car, and she was ready to start the process. The car didnt sit til 4:30pm, car was strapped to dyno shortly after 12:30 pm, I actually began working on the tune at 1:09 pm. The combo on this car is definitley less than desireable from a tuners stand point, and there were several issues that had to be worked out before it was even worth making a dyno pull. Although the car didnt make a pull til 5:30 pm, I had made several changes to the car setting idle, fuel trims , tip in fuel ,and reworking the maf tables etc..The dyno is great for the wot pulls, but the car needs to run before you pull it..The car was close, but I wasnt going to push on , as I felt a fresh mind on the car in the morning would be best.
Started back on the car the following morning, had a coulpe of issues with the plugs, got past that and had the tune 80% done (still needed the road testing and touch-ups), but with some concerns about the amount of KR the car was showing ,not to mention it had a few plugs with cracked porcelain. This was dicussed with the owner, but instead of concern for safety, all I got was greif over the lower than expected dyno numbers. He felt he may have gapped the plugs wrong and thats why they cracked. He wanted me to replace the broken plugs, and he would return them to Amazon. Nevermind the fact, I told him I felt the car wasnt happy and was detonating.
I explained to the customer before the car was even brought in that 17 psi was too much for a 3v on pump with stock heads,cams, and cats. Also he was told to make sure the car was dyno ready. The classic reply..on the net I saw the same combo make x amount of power crap. He wanted to move forward with the methanol and 17 psi.I agreed to give the meth a shot and see what I could pull from the car, I wanted to lower the boost, but I would have to work it into the schedule. This conversation took place Friday the 11th.
Customer came and road tested the car yesterday, and with the exception of the cold start (which was fixed) was happy for the most part. He said the car lagged below 3k, I explained to him that was the by-pass surge valve design. I told him we could change that and the car would have instant boost when he rolled into the gas. He said that would make him happy and just wanted to see more power, that 530 wans't enough ,although the car did feel good.
The customer says he never got updates, he got updates, just didnt get me on the line. I did speak with the customer for over 40 minutes last night regarding his car, the combo,pros and cons of fuel,boost,timing,meth, meth mixture, the ways to use meth for either cooling or power,cams, mafs, maf meters, blower speed rather boost as a reference, etc. Everything seemed ok last night. I wasnt able to get the car back on the dyno til today. Last week was completely booked. I actually had the car on the dyno tonight (1-22-13) with lower boost. The car was at 11.9 psi,and seemed to struggle to make 500RWHP, but sounded clean at 490. I called the customer again, and explained to him my concerns about detonation,and hurting the engine with his current combo. Once again, I got grief, why, and thats not enough power. I want more boost and more power. His request lets try 15 psi, and see what we can get with methanol. My reply ,which I said a few times already,I dont want the blood of his engine on my hands. That with more mods..heads, cams, no cats/hiflows, his back pressure would drop and he would see more power. Bottom line, I cant magically make the car produce more power than its capable of on the current fuel/combo. If the A/F is spot on, and timing is where its happy (16* peak), it is what it is.
The trailer..I told him I didnt rec leaving the trailer, but he could do so at his own risk. I never once assured him it would be safe and secure. I am truly sorry it was stolen, but it was his decison to leave it. I didnt agree to baby sit it, and he definitley could have picked it up sooner.
So tonight I get this thread brought to my attention . After several calls with the customer since this was posted,he never made mention of this. My response to Charley, heres your car with a temp tune to drive her away.The by-pass valve is locked open, I dont rec running the car on boost. NO labor will be charged and we will move on. Charley's response in a short version, was he really wanted me to complete the car and he would fix all this on the net. I told him I'd re-consider working on his car, but I wanted to think about it over night. Well, I've decided..NO.
Keep in mind Im into the car over 6 hrs now, plus my techs time, and she was just about done. Id rather lick my wounds and move on, than have his car cough on my dyno or in his hands due to lack of experience and common sense. Good luck to the next one who works on this car.
Adam@ST
sorry about any typos..its late.
