Today I removed the front bumper cover to swap heat exchangers. Here's a picture of the Afco 80280NDP Dual Pass Heat Exchanger prior to removal. Notice I previously installed dual 5.2" Spal fans.
Here's a comparison of the 80280NDP Dual Pass Heat Exchanger to the 80280PRO Pro-Series Dual Pass Heat Exchanger
Here's some dimensions of the tanks and core not including the mounting brackets, inlet/outlet tubes or fans
80280NDP
- Core - 23.000" wide x 8.750" tall x 2.250" thick = 201.250 sq. in. frontal area or 452.800 cubic inches
- Tanks - 1.625" wide x 9.000" tall x 3.000" thick = 43.875 cubic in. ea. or 87.750 cubic in. total (both tanks) and hold a total of 48.6 oz. of coolant
- Overall - 26.250" wide x 9.000" tall x 3.000" thick
80280PRO
- Core - 23.375" wide x 11.000" tall x 1.375" thick = 257.125 sq. in. frontal area or 353.600 cubic inches
- Tanks - 1.375" wide x 11.375" tall x 2.375" thick = 37.100 cubic in. ea. or 74.300 cubic in. total (both tanks) and hold a total of 41.2 oz. of coolant
- Overall - 26.125" wide x 11.375" tall x 2.375" thick
Summary
- The 80280NDP has a 99.2 cubic in. (21.9%) larger core
- The 80280NDP has 13.45 cubic in. (15.3%) larger tanks - holds 7.4 more oz. of coolant
- The 80280PRO has 55.875 sq. in. (27.8%) more frontal surface area than the 80280NDP
Some additional things to keep in mind:
- Both heat exchangers have a large portion of the core blocked by the front bumper support. The 80280PRO should have an advantage in that regard, as that same portion of the heat exchanger now has air flowing through it due to the dual Spal fans
- The 80280NDP has 21.9% more total core area. However, because that core is .875" thicker, the air flowing through that core may be heat saturated and not able to absorb any more heat.
- The 80280PRO has a 27.8% greater frontal surface area that the 80280NDP. This should result in greater heat dissipation.
Here's a couple pictures of the installation
You'll notice in this next picture the combined thickness of the Be Cool Radiator and Afco Pro-Series Dual Pass Heat Exchanger. The reason I have less room in front of the radiator is because Be Cool moves the A/C condenser, transmission cooler, and P/S cooler forward approx. 1.0". This makes for a very tight fit between the heat exchanger and P/S Cooler & A/C condenser
In this next picture you can see the bottom of the Meziere WP136S 20 GPM I/C pump which fills the heat exchanger from the bottom
I haven't been able to test IATs yet as I still have to fill the system with coolant and wire the fans.
I will be using the dual relays, fuses & harness supplied by Afco in conjunction with a coolant temperature switch in my I/C reservoir. The fans will
not be wired to run all the time. When coolant temperature reaches 113* the fans come on and stay on until the coolant temperature drops to 100*.
Here's a link to Spal's website which has all the specs on the dual
VA11-AP7/C-57A fans included with the 80280PRO.
I also want to check the decibels of the fans when there running. I'll post the results.
stay tuned for next weekends results
