tmcolegr
It's All About the Build
27.5x 6.5x 2.5
Peter does the 27.5" width include the tanks or is that just the core? That sure seems awfully wide considering both Afco units aren't that wide including the tanks.
Nonetheless, based off of those dimensions when compared to the Afco heat exchangers, the Gords core has:
Frontal Surface Area
Gords has 178.750 sq. in.
80280NDP has 201.250 sq. in.
80280PRO has 257.125 sq. in.
Core Cubic Inches
80280PRO has 353.600 cu. in.
Gords has 446.875 cu. in.
80280NDP has 452.800 cu. in.
Core's Restriction to Coolant Flow
80280PRO dual pass has 176.800 cu. in.
80280NDP dual pass has 226.400 cu. in.
Gords single pass has 446.875 cu. in.
Looks like the Gords H/E has the least restriction to coolant flow due to it's large core size and due to the fact that it is a single pass design. However the smaller frontal surface area may hinder it's ability to dissipate heat as well as the larger Afco H/Es.
