bcb06gt
Thanks for the post. I have the standard dual pass Afco with some small Spal fans mounted behind. I have always thought about switching mine out like you did. Curious to see the IAT difference and noise difference.
How does the noise of the new fabs compare to your old setup with the two smaller fans?
Any chance we could get some pics of how you mounted the temp switch in your reservoir and also where did you buy this switch from. How did you wire it? I just installed the Afco dual fan on my 500 and while i cant hear the fans while driving it would be nice to be able to switch them off when they aren't needed. Thanks
If the dimensions of my Gordsford HE single pass helps I can give them to you.Does anyone have a stock GT 500, KB, Roush or Whipple H/E handy that they could give me precise measurements (+/- 1/8") of the core area (not including tanks)? I would like to compare the Afco H/Es to those H/Es as well.
PS: when measuring the core thickness, please use something thin like a shipping tag wire to run through the core and get an accurate dimension
thanks
What do I need to datalog to see if the car is pulling timing?
27.5x 6.5x 2.5If you want to give me the dimensions of the Gord's HE core (length, width & height - not including the tanks), I can tell you how the Gords compares to either of the Afco units.
